Rotors Disenigrated
Old 12-18-2008 | 03:26 PM
milehighmike's Avatar
Rotors Disenigrated
I have a 97 2500, and as I was driving, my truck started to shake really badly. I pulled over and walked around, couldn't see any thing wrong, so I started it back up only to find that I had no front brakes. I limped home and pulled my front tires, only to find that the entire stopping surface on both my front rotors wasn't there anymore. Does anybody know what could have caused this? I had my brakes start squeeling only a week before, like I needed to replace my pads soon, but there was still pad left when I checked it.
Old 12-18-2008 | 04:08 PM
mahdey's Avatar
hub assemblies tend to do that to rotors when they get bad.
Old 12-18-2008 | 06:45 PM
infidel's Avatar
Could be a few things:
Pads too hard for the rotor, these are usually the "lifetime warranty" type.
Caliper not retracting due a dirty/rusty cylinder.
Brake line falling apart internally causing it to behave like a one way valve.
Bad rotor bearings.
Old 12-18-2008 | 07:46 PM
dozer12216's Avatar
Pads wear uneven and appear good when not. Calipers hanging generally a cause. Driving with foot on brake pedal. Poor maintenance or none.
Old 12-18-2008 | 08:19 PM
Junk Man's Avatar
Was truck pulling to 1 side when braking? That would indicate hanging caliper. Caliper could have been bad or slides in need of lube.
Old 12-19-2008 | 12:58 AM
My truck did start pulling to the left side about the same time that the pads started squeeking. Would that mean I should rebuild my calipers, just to be on the safe side?
Old 12-19-2008 | 07:50 AM
blackimpala's Avatar
Well, you could rebuild or replace the calipers but I would first pull them and insure that all the sliding parts and surfaces are cleaned and lubed. This cured my truck of pulling.
Floyd
04ctd
08-03-2007 04:19 AM
towin1JT
14
10-29-2003 08:51 AM
Scubasteve
09-03-2003 08:19 PM
Madoco
08-13-2003 09:42 PM
11-22-2002 01:22 PM
Quick Reply: Rotors Disenigrated
