Rocker panel rust
Rocker panel rust
I had my rocker panels sprayed with linex a few years ago. Today, I noticed the linex was bubbling out. Well, after further inspection and peeling the linex off quite easily, my rockers and cab corner on drivers side is rotted through. The prep was not done right, so now, after haven't them sprayed to prevent this problem, I have to go through the hassle of getting them fixed. The ******** that did it should be responsible for the bill. Can't get anything done right unless you do it yourself.
Any picts? sounds extreme! Maybe the Line X held the moisture close to the metal all year around?? all my rigs except the 2 Civic's and WRX have been out in the rain 365 days a year + we get 120" of rain here and even my ageing 1985 VW is 99% rust free to this day, Super strange for a cab to rot threw- I have actually never seen a modern truck with cab rust- Check this video out, the rocker panel on the VW is chiped up and still no rust- http://www.youtube.com/watch?v=yo-YUR1_DaU
Chances are there was rust BEFORE it was Linex'd
Possibly it was fixed before by a body shop? Do you know history of the truck? It could've been hit there and body shop didn't fix it properly.
Need to cut it all out and prep inside rockers, Use good quality epoxy primer to prevent metal from rust.
Looks like the rust pushed thru from behind, as is the case usually with these truck doors.
Trying to get anybody to warranty anything nowadays is a waste of time. Especially any service type operations, I tried to get a replacement taillight for my 97 tahoe to replace the junkyard garbage they put in and called "new". They needed the rig for an entire day, weren't sure they could cover the cost of 57 bucks because it had been three years, even though a "lifetime" warranty was included in the repair. I also found out they subbed out the work on my vehicle to another shop, but that is another story.
Long story short, e-bay $19.99 free shipping. I'm over it. My time is worth more than that.
If you want it done right.........
Sorry, that looks awful.
A good prep job is a key to a good paint job.
"just rock chips" now we have a problem. you see when rock chipped paint it probably went through paint/primer all the way through to the metal. Exposed metal = rust. No wonder they call it cancer. It took a few months/years on your truck to spread out and crawl underneath LineX.
I agree that it was not prepped correctly if it will "peel right off".
If you have ever tried to remove it, its awful. The best way is with a wire flapper wheel and a big grinder.
Not trying to discount what you are saying, just throwing things out you may have to face when they deny your claims.....
I am not gonna bother with a claim to them. Your right, it won't do any good. I just went out and peeled the piece from the front of the bed to the wheel. Came right off. I will have the rockers fixed and take it to a different linex to have it resprayed. If the rest of the truck wasnt sparayed I wouldn't even mess with it.
I agree with sixlugs first comment. I think the rust started from the inside. Mines doing it now, small bubbles of rust, the paints not even showing a hole or rust trail yet just bubbles. There are drain holes that get plugged or just hold debris in the rockers. Our winters with the salt and chemicals dont help!
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
I just wouldn't even know where to start. I checked the rest of the truck, and all seem's to be o.k. at this point.
