Replacement rocker panels? 2nd generation
I am looking for replacement rocker panels for a '99 extended cab. I have searched and can not find them. I can only find ones for a regular cab. I also need rear cab corners. I have not yet tried the Dodge dealership. Does anyone know of a source for these panels?
cab corners: http://autobodyspecialt.com/
Check www.lmctruck.com
How is the stuff from LMC?
How much should one expect to pay to have this repair done?
Looking at autobodyspecialt, it looks like D112 is what I need, but that is probably standard cab.
I think it's part # 7 here. I really just need the part that is on the outside.
When my rockers and cab corners rotted out I went and got an estimate from a local body shop. Holy cow they wanted a lot of money to do the work!
I just bought cab corners and rockers myself and cut them off and sandblasted the area free of rust inside and out. Then I sprayed some phosphoric acid / zinc treatment and epoxy primed it when done. I managed to save the front of the panels so I didnt need to remove the fenders. I cut the corners in such a way that I didnt need to remove the bed. Just welded them on and re-sprayed some rust neutralizer and paint in there.
The job was a royal pain, but it came out good.
I bet theres some videos on youtube that would give you a better idea on how to do it if you decide to do the job on your own.
schamran
0
12-14-2013 05:56 PM
1generationkid
07-07-2009 12:44 PM
Ram95
09-13-2007 11:16 PM
Chip
15
12-06-2004 03:48 PM
