rearview mirror green light???
Old 11-27-2010 | 11:42 AM
sluggo42's Avatar
My rearview mirror has a button on the bottom that turns green when you push it up, but it goes out when released. It will not stay pushed in, and it also doesn't stay lit up when released.
Is it supposed to stay locked in? Is the green light supposed to stay lit?
I ask because I'm getting blinded by the jerks who like to drive with their high beams on while tailgating me...
Thanks, I just want to know how this mirror is supposed to operate, or if I need to go to the junkyard and get a "new" used one..
Thanks for your thoughts in advance!
Doug
Old 11-27-2010 | 05:18 PM
gorms's Avatar
That light is supposed to stay on with the key on once you hit the button. Sounds like the switch is all that's bad. Auto parts stores have replacement mirrors, I think they usually work well and aren't all that much money.
Old 11-27-2010 | 06:31 PM
sluggo42's Avatar
negative on the auto parts stores, they all direct me to the dealer.
So, then if I understood you correctly, you are saying that when the truck is running, if I push the button, it should stay latched in an remain "ON" ?
Will the button actually stay recessed a bit when latched? I'm guessing that the catch has broken on mine?
When I press it, it turns green, but it won't stay when I push it.
Anyone? Again thanks...
Old 11-27-2010 | 06:35 PM
torquefan's Avatar
Yep, It's supposed to latch "on" and stay recessed.
Old 11-28-2010 | 12:14 PM
Don T's Avatar
I installed (http://www.whitenight.com/) on the back hitch on my truck and will turn them on if tailgater has his lights on bright. They are bright and that usually gives them a clue to back off lol
Old 11-28-2010 | 03:08 PM
SIXSLUG's Avatar
I had a pair of 1000W facemelters on the back of my pre-runner for tailgaters for the same reason. But I'm all grown up now!
I have noticed a lot more light splash directed upwards on newer cars, which is odd because I want it ahead and on the ground where it belongs. I dip my side mirrors on the highway anymore and use the convex mostly for changing lanes.
I just checked my switch and it stays pushed in and lit with the Key ON.
Old 11-28-2010 | 07:39 PM
sluggo42's Avatar
So I took the mirror apart last night and found that there is a micro switch soldered onto a circuit board. Pretty complex mirror!
Anyways, my switch is bad, and while it works when pushed in, it won't stay in. So, I pushed it in, and tied it closed with some fishing line. Now that I think of it I should/could have used a little tiny tye-wrap...
Anyways, it's on all the time now, so we'll just go with that for the time being...
Old 11-29-2010 | 12:06 PM
SIXSLUG's Avatar
Inginuity is the mother of jerry rigging!
Alaska700
0
10-02-2012 03:58 PM
kokalit
07-29-2009 04:42 PM
Purplezr2
07-29-2008 03:20 PM
dtrkstan
05-26-2006 09:53 AM
I SPEED
13
03-16-2005 01:39 AM
