Rear Brakes
Rear Brakes
Anyone had any rear brake problems. My '01 has 75000 on it, and the rear inside pads are nearly gone, actually the driver side is gone. I pull a trailer occasionally, but not daily or weekly. It just seems odd @ 75000, and ecspecially only the inside pads, the outer pads are fine??? Anyone had a similar problem???
Are you kidding me? 75K miles and you think the pads should last that long? I've put a dozen set of pads on the front of my truck in 182K miles. It takes ten mins tops. Change them before you gall up the rotors.
Sorry, I now see you are new to the site. Welcome.
I just spent 48 hours with my step daughter's husband's parents. My head hurts!
Put new pads on it, re-grease the slide pins and ways.
I was more confused to the fact that the inside pads on the rear were gone, i've already replaced the front once. Whats wierd is that the outer pads on the rear are 75% at least....oh well
If the caliper binds it will wear one pad faster.
I only got 125k on my front brakes. Never can understand brake wear. I put the second set on Mommy van today at 108k
Originally Posted by IHMAN75
So whats your opinion on pad brands.......OEM or cheapos
There is a reason the cann them "lifetime" pads.
The rear pads are not going to wear nearly as fast as the fronts, but keep in mind that better quality pads always outlast lesser quality pads. You don't necessarily have to get OEM (from the dealer), but when you go to the parts store, assuming they carry those pads (there have been some issues will getting aftermarket pads for some years, but I don't remember exactly what years), don't get the cheapest thing they carry.
Napa carries good ones, Ceramix for instance.
Hawk, I have heard are very good.
Performance Friction are good.
Chris
Chris
Thanks for the input. I agree with putting on the medium grade. I've had crappy luck with lifetimes, and el cheapos.......Unfortunatly, I gotta replace my rotor/drum this time round, ate right through it.
Good luck, and don't be a stranger.
Had the same problem you have, had to replace rotors and pads The slide pins for the caliper had siezed up. When you replace the pads and rotors make sure the pins are in good shape and replace the rubber bushings the pins ride in as required. Definatly take them apart and regrease them at the very least or the rotors and pads will get eaten again. As for what pads you get I will leave that one up to you.
1992 Renegade
10-11-2014 03:29 PM
2500CTD
10-19-2010 07:10 PM
JImbo1
13
04-18-2003 06:44 AM
