rear brake woes
rear brake woes
ok guys, I had the rear brake lock up problem this winter, it seemed to go away thing warmer weather. But the other day i drove off with my e-brake on ( its weak anyway) and i drove about 30 miles. Almost home and she started shuddering very bad. I stopped and figured out that the brake was on, but now every time I step on the brakes it shudders quite bad. Can the rear drums warp? I guessing thats where the shuddering is coming from. Any ideas would be helpful. Im getting around to redoing the brakes anyway just got too many irons in the fire. ( how come thats always the case? lol )
More than likely your going have turn the drums and replace the shoes for sure! But you might have to replace the drums too...
At this point you might think about the Chevy wheel cylinder kit too... (Some chime in with info)
Check to see if the park brake is releasing the cables maybe stuck sounds like your due for a brake job. I would do the gm wheel cylinder conversion cheap and effective.
Originally posted by Magaliasram
Are the GM wheel Cyl. bigger?
Originally posted by dieselnut55
Are the gm wheel cyl a larger cyl then the one on the 3500 rear?
That's what I was thinking, the 1 ton were the bigger, and this was a 3/4 ton mod. If my memory servies me right this is what the 1st gen people did in the 3/4s. I'll go to NAPA tommrow and check it out, am getting ready to tear into the rear breaks on this and if it is any larger will do it
Just did mine...
Followed infidel's advice and also bought the cheapest shoes I could get. Not really noticing much difference, but then again, my old brakes were at 85% and only needed replacing because the rear axle seal (driver's side) leaked all over the cylinder.
I'm estimating that I won't need rear brakes for a long while!!
samahi72
07-23-2007 04:15 PM
