Proper placement of floor jack for rear end?
Location: Newman Lake, WA (But my home is deep in the heart of Texas!)
Just curious....................
I had my new 315s siped last week in anticipation of the snow/ice that has arrived here in Spokane and noticed that the guy at Les Schwab put two floor jacks under the front axle yet only one in the rear, directly under the diff. housing.
Is this o.k.????? The owners manual shows the correct location on the rear axle, one on each side on the axle, not under the differential.
Can anyone comment?
Thanks!
Tom
Can anyone comment?
Thanks!
Tom
You can do it that way but if it was me, I'd use 2 floor jacks - reason being is that the truck is more stabilized and less likely to "lean" or possible slip on the jack to one side or the other..
Administrator / Scooter Bum
I place the pad from my floor jack in the middle of the spring plate that the u-bolts pass through.
Then place jack stands under the axle tube for "Just In Case".
always use jack stands or big timber whatever you have jack could fail or slip off just good practice I keep some chunks of gluelamb beam in the bed just in case I get a flat
Jacking from the center of the differential on the rear is OK. Everyone is right, you do loss stability but unless your dancing around in the bed or running the engine with the tires moving, I wouldnt worry about it. They use two jacks in the front because the differential is off to the side, so I believe they lift from the suspension arms on both sides.
they want all 4 off the ground at the same time so they put 2 in the front, eiaser to balance, and one is enough in the rear if you have 2 in front or the front is on the ground. 3 jacks is very stable, ive been in and out of my bed on 3 jacks. but if your going to be under it at all jack stands for sure. changing out tires shouldnt put you under the truck un less your getting your spare which is easier when the trucks on the ground any way. ill stop now
I always use stands if the tires are comming off....
I had a jack twist sideways once and the car fell on my chest....luckly my brother was there to jack it back up....I was just my buddies little geo, but still, it pinned me to the ground pretty good, didn't break anything (thank god)...It was a stupid thing to do, I tried to save time and didn't place stands...I always use them now...
iowagn
04-15-2006 09:41 AM
