Project frame swap has begun!
Old 08-10-2007, 08:42 PM
95black2615's Avatar
Bought another frame for my truck a few months back and am just now starting on it.
The frame currently under my truck is bent pretty bad. I bought it wrecked that way and have been driving it like that for awhile. Finally found a replacement frame for it.
The donor frame is from a V10 truck and it is identical to my diesel frame.
I'm just going to do a frame up restoration. I stripped the donor frame yesterday. I already have one frame rail almost completely ground down and all the scale off today. I'll be painting it tomorrow. I'm gonna run all new brake line since everything is stripped.
Just bought a new front bumper with plastic, grille, and new diamond cut one piece headlights/signals.
I'll try to snap a few pics tomorrow.
Old 08-11-2007, 12:59 PM
Stamey's Avatar
If you didn't know, prime it before you paint it. Better results.
Chris
Old 08-12-2007, 12:27 AM
wcbcruzer's Avatar
Man, have fun. It'll be a nice payoff in the end.
Old 08-12-2007, 03:06 AM
qcstunter's Avatar
I'm glad to see someone doing this. I also bought my truck wrecked and would like to change the frame later on.
Old 08-12-2007, 10:37 AM
SIXSLUG's Avatar
If you bought an early frame check to see that it had the supports by the shocks mount welded in. These frames had a weakness that caused cracking around this area. My dad's '94 V-10 got a recall notice for this problem back in '96, if I recall correctly. Its a relatively minor repair but makes the frame stronger in this area and might be easier to do before assembly. Just a thought, Kurt
Old 08-12-2007, 11:13 AM
Can you detail a little more? You talking about the rear shocks? I'll try to snap a pic today of the area. Sure would be easier to get it welded up now if it needs it.
Old 08-12-2007, 03:33 PM
bob4x4's Avatar
It is the front spring tower that gets reinforced or replaced
Bob
Old 08-12-2007, 09:52 PM
kxhonda's Avatar
I am getting very close to getting my frame swap done. I just drove it tonight for the first time in 5 months. It felt so good. I'll have some more pics up soon...
My Gallery
Old 08-13-2007, 05:35 PM
SIXSLUG's Avatar
It's the front shock tower area.
Old 08-13-2007, 06:19 PM
My Gallery
Your link doesn't work.
Old 08-14-2007, 12:14 AM
kxhonda's Avatar
Its just a link to my member gallery on here.
Old 08-16-2007, 04:43 PM
The Patient:
The Cure:
Old 08-17-2007, 12:13 PM
PaulDaisy's Avatar
Man, that is a lot of work for a slightly dented front bumper
Good luck!
-P
Old 08-18-2007, 05:59 PM
TxDiesel007's Avatar
Bob
any pics of this?
Rick
Old 08-18-2007, 06:25 PM
TXaggie09's Avatar
Where did you get those headlights and are they any better than stock?
Quick Reply: Project frame swap has begun!
