Power steering trick didn't work...
I used an old socket extension with a bfh, and plenty of PB Blaster. Just don't hammer to long on any single bolt. If you have some old bolts that you could swap in for this it may be better, or you may need new ones when you are done.
Well I got them off. I had to do the power steering trick while beating on them with a sledge. The bearings seem fine even after all the abuse but I think I will change them anyways. I envy anyone who lives where they don't salt the roads.
What trick are you guys talking about? I just replaced one of my front rotors, I can't get the hub bolts out on the other side, already sheered off 2 3/8" to 1/2" adapters because I don't have a 1/2" drive 9/16" socket...I think I'm gonna have to go get one. And I can't get the Hub nut off the Pass. side, I mean I'm 240 and I'm jumping on an 18" breaker bar with the 1 11/16" socket on the (&*# thing and it won't move, I've hit it with PB Blaster quite a few times too and still can't get it...
You back out the 4, 12point bolts and brace a socket and extension against the frame. Then use the power steering to turn the knuckle into the socket so the socket presses against the 12pt bolt, and presses the hub out. This can be dangerous with the truck running up on jackstands above your head, so safety is your responsibility.
As far as the axle nut... I ground through one side to just before making contact with the threads. Then, split it with a chisel. It came off by hand then.
This was on a 2001. Yours may be different.
nismo3183
11-02-2014 06:47 AM
trik396
01-07-2014 11:40 AM
westcoaster
02-26-2008 10:41 AM
