power contols acting weird
ok, i had some body work done at the dealer in which they must have removed the door panels. got it back and the driver power control switch was not installed properly (not sitting flush with the arm rest). ok, no big deal - that's easy to fix - BUT now whenever i toggle my power window switches (both driver side and single pass side) it activates my door locks!!
went back to the dealer and they said they would start from the source and try a new switch - if that doesn't work he said it might be because i installed the LMC headlight harness!! i find that hard to believe, it sounds like they are going to try and get out of it that way. it has to go back on april 30th to touch up some minor flaws they made and that's when the switch will be checked.
i have taken apart and re-installed the door panels and switches many times with no problems before - its a pretty simple job.
anybody ever had similar symptoms? (with or w/o the headlight harness)
MoreSmoke
02-22-2004 08:50 AM
