passenger window wont go up and is all the way down
Hey everybody my passenger window won't go up at all and it is stuck al the way down. The only noise it makes is a click when you push the swicth in the down direction.
Thanks
Thanks
I've had trouble a couple times with the same thing on our Durango. Both times I pulled the switches, pulled the wire connector off and worked the switch pretty hard a few times. Put everything back and the windows would work fine. Still don't know where the open connection was or if the switch just didn't want to work. I didn't hear either one do any clicking but it may be that I just couldn't hear it.
I beleave it is the window moter. I tested the swiches and thy seem to work alright. It was working pritty good a little slow going up and then it would not go up at all. I have a moter. Waiting for me at the parts store just don't have the cash to get it yet. Thanks for all the help.
Try smacking around the motor area with a rubber hammer. My 02 passenger side window stuck in the down position. After checking and cleaning the switches and power to the motor, I whacked the motor and lift regulator area with a rubber mallet and it has worked ever since.
I figured it out it was a broken wire end on the main switch on the drivers side. Soldered the wire back to gether works great. After buying a new motor and cuting the wires because the new one has a different wire plugin. Owell got a spare window motor. Thanks for all the help guys
pullin hard
09-26-2006 08:54 PM
NoSparkplugs
04-08-2006 12:14 AM
BigBlue
15
01-06-2005 08:34 AM
Journier
12-18-2004 08:26 PM
