OBDII connector unconnected
I pulled my code reader from the connector and the whole connector separated from the wires. Can someone take a photo of the back of thier connector and post it so I can try do decipher where these wires go in the plug. It's hotter than haitis here and I don't have much time to fool around with it. I'm not in a hurry, I just don't want to spend a lot of time under my dash right now.
Any help will be appreciated.. Thnx
=Pete
=Pete
I uploaded a photo of the data link pin outs at 9.0PM it's waiting approval. So check my photos in a bit. If I'm stll here when it gets approval I'll tack it on to a post.
I can't get a picture (tried) but hope this helps some....
I had to search the internet for a LONG time just to find this but also found some info I needed so it wasn't a loss.
DATA LINK CONNECTOR - BLACK 16 WAY
CAV CIRCUIT FUNCTION
1 - -
2 - -
3 D1 18VT/BR CCD BUS (+)
4 Z2 20BK/LG GROUND
5 Z12 18BK/TN GROUND
6 D20 20DG SCI RECEIVE
7 D21 20PK/DB SCI TRANSMIT
8 - -
9 - -
10 - -
11 D2 18WT/BK CCD BUS (-)
12 - -
13 - -
14 D220 20WT/VT (DIESEL) SCI RECEIVE (PCM, DSL)
15 - -
16 M1 20PK FUSED B(+)
Here is the picture of the connector:
1 - -
2 - -
4 Z2 20BK/LG GROUND
8 - -
9 - -
10 - -
12 - -
13 - -
15 - -
I think we both gathered our information from the comprehensive repair manual from dodge/cummins... I found mine on-line I think BusBoy might have had his own copy and took a picture of the connector and pin-out.
I tried to get a picture of the actual connector, but my camera would not focus that close to the lense. You should be able to put it back together with the info we provided. Just remember when your LOOKING at the connector pin #1 is upper right corner and pin #8 is upper left corner. Just like the picture shows.
Hope that helps
-Tim
Hope that helps
-Tim
KatDiesel
09-03-2004 09:13 AM
