Not Heating up
Old 12-09-2005, 10:59 AM
thedblc's Avatar
Heater hose restrictor removal.
see http://dodgeram.org/tech/dsl/trouble.../isb_noise.htm.
They refer to a restrictor in the heater input hose that can be removed. Mine was already gone.
Old 12-09-2005, 11:19 AM
lglamb's Avatar
Originally Posted by thedblc
I have been using the recirculating heat options ...
Ok, I missed this page in the owner's manual. How do we do
the recirculate heat thing?
Thanks,
Lowell
Old 12-09-2005, 12:13 PM
CoastalDav's Avatar
Originally Posted by TORQUE
Check your rotary heat dial for full range of heat(may be stripped) or stuck on cold side. If engine is up to temp, heater hoses should be hot also(inlet hose is hotter) . If engine is still slightly cold(not into normal range yet), inlet heater hose should be slightly warm to the touch already. Check coolant level, check if water pump is circulating, and put on a winter front of some sort(check out my pics).
The rotary temperture control **** in the truck is operated by 12Volts. As suggested above, it could be bad. I had one go bad in my truck. About 70 bucks.
Dave
Old 12-09-2005, 12:14 PM
infidel's Avatar
Thanks,
Lowell
Turn the **** to the position that shows a picture of a truck cab with a U-turning arrow though it.
fisherjaw
01-11-2010 09:42 PM
patdaly
01-25-2007 11:56 AM
simonswb6
08-27-2003 05:21 AM
KC
01-14-2003 06:30 AM
Quick Reply: Not Heating up
