No rear lights!
No rear lights!
OK I have a 1999 ex cab 4x4 auto dodge diesel and was driving last week and my driver side blinker went out I replaced the blinker and it worked fine for about one day then went out then worked then my passenger blinker went out and my driver side worked and now they are both not working and I have rear lights at all fuses are good and so are bulbs no apparent breaks in any wires. Any help would be appreciated.
Sounds like you may be(have) lost the ground for rear lamps.
Does the CHMSL work. It has a different ground.
My 2000 FSM shows tail and stop lams ground to frame just ahead of left battery.The front fender lamps ground through same connection.
Check for voltage in sockets for bulbs to figure a ground or power problem. The black wire is ground for all these circuits.
The common statement is check all connectors and grounds for quality connections.
proudpapa97
05-04-2008 06:50 PM
cummins dsl
22
06-27-2005 11:53 AM
MoreSmoke
22
01-10-2005 03:05 AM
CHarlan
08-06-2003 08:40 PM
