NO CRUISE P1683 code!
Hello to all, i have had no cruise control for months and have tried to fix it many times but no luck. my Snapon scanner says code P 1683. i replaced switch and clockspring and heated air soloniods , checked all wires i could see.
anyone have any ideas as to where i should look?.
1996 Dodge Ram Cummins, 4x4, 128000 miles, auto trans.
Unless you spent $1200 from Chrysler for DRB software for your scanner doubt if it's reading right.
The common OBD system doesn't start until '97.
Most common causes of no cruise are a rotted vacuum hose under the battery or a bad brake light switch. Since the switch is only $11 from Napa I find it easier to just swap in a new switch rather than test the old one.
I checked the brake light switch today and it is working right. and i have the little green light on the switch on the steering wheel coming on. so what should i check next?.
The switch is working. what i think is the problem is the computer. P1683 says S/C power relay circuit. the computer controls the speed control. i checked
the servo wires and they are good. all vacuum lines are fine. i am not 100% sure about the computer being bad. would like to fix it myself before going to ***********.
O.T
09-06-2007 06:10 PM
trophystock
07-06-2006 06:28 PM
CTD NUT
04-05-2005 04:45 PM
DF5152
02-10-2004 10:33 PM
