No brake lights or turn signals
I have a 97 3500 5speed and have no brake lights or turn signals on the rear. but have turn signals and flashers on the front of the truck but not on the rear. Also my ABS light and brake light are on. I have been working on this for a couple of days and can't figure it out.
I have replace the brake light switch and replaced both flasher relays or fuses. and there are no blown fuses
thanks for any help that you can give.
This just happened to me on Christmas Day . Under to hood on the drivers side where the fuse box is open it up and at the top there are 2 or 3 20 amp fuses. I bet one of though are burned out . buckskin
You never mentioned it, and I hope its a given, but did you check the bulbs? They're dual filament bulbs, so even if you still have running lights, you may not have brake/turn signals.
Yes I even replaced the bulbs and still nothing so I checked to see if i was getting power to the bulb and nothing.
I will check those fuses other fuses tomorrow.
Thanks Heath
Thanks Heath
Rbhart
03-01-2013 08:34 AM
redruM Hauler
10-06-2007 09:18 AM
