no brake lights
no brake lights
I have no brake lights on my 98.5. I have turn signals, flashers, parking, running lights. I also have the top rear cab brake light and it works fine.
I have changed fuses and bulbs. change both the 40 amp trailer fuse and 20 amp stop light fuse. they were good and are still good. it seems as though the turn signal uses the same wire and filament as the brake light and the turn signal works fine.
any idea's ?
any idea's ?
I would have said brake lite sw but the cab brake lite works, I would try a different flasher unit for the turn signals then try the hazard lite sw to see if smooth, if not try cleaning it.
My thinking was.. what over rides the brake lights? Hazard warning lights and turn signal on the one side...I haven't had a chance to look at WD's but I'm thinking the hazards aren't retuning to normal, switch or hazard flasher.
I had already changed the bulbs, and I replaced the brake switch with one from my 96 truck. I think it is the turn signal switch but will follow up on that next week.
polaris800sp
11-13-2008 05:35 PM
proudpapa97
05-04-2008 06:50 PM
CHarlan
08-06-2003 08:40 PM
