New Nittos - Tire Pressure Question
What does the sidewall say is the maximum pressure they can handle?
If they are 65-80psi tires, then that will probably work.
If they are 50psi tires, then no.
phox
phox
They are 10 ply, load range E and the sidewall reads max of 65psi. I had Firestone Steeltex's 265X?X16 load range E, max of 80psi on when I first got it used to run 65 f 55 r and it rode fine. The Cooper 305X70X16 I just took off were load range D, max 50psi and I used to go 45-50f and 35-40 rear. They were a 50k tire and lasted 46k.
I'm looking for comfort and longivity so appreciate the replies.
Thanks for the replies I guess I'll stat @ 60 f and drop down a bit to 45 in the rears and do the chalk mark on the tread test to see where the road meets the tire.
chucktuna
12-07-2006 07:40 PM
chaos24valve
09-19-2005 05:15 PM
hotdram
11-04-2003 03:10 PM
dsljunkie
08-11-2003 12:08 PM
