New member with '97 4wd...want to fix up my steering
It's time to start fixing up the front suspension/steering on my '97 4wd 5spd w/10ft flatbed, and after seeing how expensive some of these parts are, I want to be sure and use the best components I can afford to avoid repeating the same repairs for as long as possible.
Tie rods & trackbar were replaced last year (with NAPA/Moog parts) due to death wobble, but steering is still very sloppy, especially left of center. I can move my steering wheel from 12:00 to 10:00 without any real change in direction. Here's what I'm thinking needs to be replaced:
-steering box - oem, AGR, or ?
-steering shaft - Borgeson or ?
-DSS - all the same, or is one brand better than the other?
-control arm bushings - look pretty cracked. Should I replace with oem, urethane, or don't bother?
-swaybar bushings and links (f&r) - oem or aftermarket?
-front axle seals (starting to seep) - oem
For the parts listed, which brand(s) would you guys recommend? Are there any parts I'm forgetting? Would like to get everything fixed up before purchasing new tires.
Please see sig for truck info. Thanks in advance for any input. Will try to post pics in the next day or two.
For your steering box, I would check out these:
http://www.redheadsteeringgears.com/
I have read good things about them.
Floyd
Floyd
Welcome to the website Sir!
I have a 1996 Dodge CTD and have pretty well rebuilt my front end. My truck has 310,000 miles on it now.
Here is my input on your questions:
1.) Steering Box- I have used the new stock ones but the aftermarket ones now available are better IMO.
2.) Steering Shaft- I highly recommend the "Borgeson!" I have one on mine and they are FAR superior to the stock unit. You can see the difference when you lay them side by side.
3.) DSS Bar- By FAR,....the BEST mod I have done to my 1996! The units are amazing at the difference they make.
Hope that helps you some.
John_P
Last I checked, ball joints, tie rods, and track bar were in OK shape as most were replaced in 2009. If any are in need of replacement, will just go with Moog from NAPA as it's convenient.
Did some more searching & reading, and it looks like the way to go is:
1) Redhead steering box (surprised to read that AGR is so bad)
2) Borgeson steering shaft
3) Any DSS, brand doesn't matter
4) oem axle seals
Still unsure which way to go for control arm bushings (urethane or oem), sway bushings (urethane or oem), and sway links (oem or aftermarket).
Also, with the DSS in place, can I still use a steering stabilizer shock? Will this help at all, or is it unnecessary with the DSS? Was thinking of going with a Bilstein unit as Ive had pretty good luck with their shocks.
Thanks all for the input.
4) oem axle seals
4) oem axle seals
4) oem axle seals
FWIW,......I would go with the OEM control arm bushings. I tried the urethane and don't feel they were that much better.
And yes,... you can use the steering stabilizer shock even if you install the
DSS!
John_P
jmccart
15
11-14-2012 04:35 PM
stirpicult
09-14-2007 12:41 PM
drtfun4x
02-08-2006 10:05 PM
Big Joe
07-01-2005 04:34 PM
zookeeper
03-17-2005 05:27 PM
