Need to drill 4" holes in stock bumper - how?
Old 02-18-2008 | 05:04 PM
CORed's Avatar
Question Need to drill 4" holes in stock bumper - how?
OK... silly question. I'd like to put auxiliary backup LED lights in my stock chrome bumper to add light at night when backing, closing gates, hooking / unhooking trailers, loading bikes, etc.
But what is the best / easiest way to drill a 4" hole into the bumper so I can install the lights?
I want them flush or sunken so as to limit damage.
TIA,
CORed
Old 02-18-2008 | 05:44 PM
strokerace's Avatar
If you have one of those dremel tools, they are great for stuff like that. If not you could drill a pilot hole and use a jig saw, if the lights your using have the rubber grommets around them they will hide some of the imperfections if your off a little
Old 02-18-2008 | 06:00 PM
caper's Avatar
I just did this mod and used my factory driving lights in the holes , tricky job lost of measureing and I used a jig saw . Ya have to cut the grommets and remelt them back together to fit the lights. I'll try and post a pic.
Old 02-18-2008 | 06:05 PM
vzdude's Avatar
DTR's 'Go to Guy'
What would be wrong with using a hole saw? You know.....the kind that goes in a drill? They make them for metal.
Old 02-18-2008 | 06:10 PM
caper's Avatar
Might work but bumper is not flat and I think it would bite a little , plus in my case the hole had to be just the right size and was not near any of my hole saw sizes.
Old 02-18-2008 | 06:11 PM
caper's Avatar
Heres a pic not a close up though.
Attached Thumbnails Need to drill 4" holes in stock bumper - how?-%7E3023474.jpg
Old 02-18-2008 | 06:13 PM
vzdude's Avatar
DTR's 'Go to Guy'
It takes a steady hand, but I have done it before. Front bumper and grill guard I installed for a customer had to have a couple of 2" holes in the bumper. Like I said.....slow and steady!
Old 02-18-2008 | 06:20 PM
displacedtexan's Avatar
I would buy a good metal hole saw and just take it easy with it like VZ said.
Old 02-18-2008 | 06:32 PM
mikmaze's Avatar
two words that help a lot : weather stripping... makes up for not so perfect cuts, and gives the edge a nice finished look.
Old 02-18-2008 | 07:31 PM
vzdude's Avatar
DTR's 'Go to Guy'
I used door edge guard from Walmart! Put the slit at the bottom, and it looked VERY slick! Cut it with tin snips.
Old 02-18-2008 | 07:43 PM
bnold's Avatar
Good metal hole saw... take it slow, but not too slow to where it is real grabby.. should be easy enough
Old 02-18-2008 | 08:13 PM
s-cube's Avatar
I use norseman drill bits with lennox holesaws. Predrill the 1/4" hole and like the others said take it slow.
Old 02-18-2008 | 08:36 PM
CORed's Avatar
So a metal 4" hole saw seems to be the recommendation after drilling a pilot hole. Awesome... thanks guys.
BTW, the standard 4" lights that squeeze into the rubber grommet... are they just UNDER 4" so they fit into a 4" hole cut by a hole saw?
Thanks much! I'll be looking for a 4" hole saw soon.
CORed
Old 02-18-2008 | 10:33 PM
Fueling around's Avatar
Be prepared:
A quality 4" hole saw is not cheap. Add more if you have to get an arbor.
If you pre-drill the 1/4" center I prefer using 1/4" stock in the arbor. On an uneven surface a drill in the arbor can easily oblong the pilot hole.
Old 02-19-2008 | 08:51 AM
high bid's Avatar
HOly s%$#@....I think you need to change your user name to "top heavy." No high speed turns for you.
whats the rating on that alum bed mount?.....pretty cool!
