Need bolt size...
Need bolt size...
Headed home tonight to do the ball joints this weekend. What size head is on the Hub bearing to spindle assembly? I want to pick up a "throw away" extension and socket so I don't ruin my good stuff. Thanks for the info!
swordfish
swordfish
If you are talking about the large nut that is on the outside of the hub and has the cotter pin thru it I use an 1 11/16" socket, it's a little big but it works...be prepared if it hasn't been loose for a while it will be tighter than tight.
thanks for the response guys....yes I was talking about the 4 inward 12pt 14mm. I got home before I read this and had to use the stuff I had. Luckily my hub wasn't stuck all that bad. I got my Balljoints done in a little over 7 hours. Not too bad this time. I only did one side also.. Thanks for the info though.
swordfish
swordfish
2007Dually6.7
0
05-18-2010 08:28 PM
cquestad
04-25-2007 04:08 PM
