My Heater Setting
My Heater Setting
The heater setting in my truck is either HOT or cold, no in between. With the temp set on blue (cold) turning clockwise it will stat cold until it gets to the blue/red then goes HOT, like it is set all the way clockwise. Any ideas?
I'm not familiar with the 2001 model but generally speaking the cable moves the heater control valve which just allows more, or less antifreeze to flow through the heater core. Verify that the control valve is working and that the cable is connected. Sounds like the valve is stuck open.
Modern vehicles have full flow though the heater core all the time, regulation of the temperature is done by a blend door which regulates how much air flows though the heater core vs. outside air.
rjm022
12-11-2019 09:17 PM
modiesel
03-07-2008 10:44 AM
