Low beams and high beams wont work?
Old 01-15-2014 | 10:33 PM
Tyeopalinski666's Avatar
Exclamation Low beams and high beams wont work?
2001 dodge ram 2500 cummins, and i don't get why but i turn the **** all the way to the right like i am supposed to and my low beams don't come on at all? and when i click the brights on i have to HOLD the signal switch towards me in order for the high beams to stay on. anyone have this problem? and how did you fix it?
electrical
Old 01-15-2014 | 11:13 PM
dubc2323's Avatar
probably the multifunction switch/ aka blinker switch. pull the plastic off the column, unbolt, unplug wires and replace. I replaced one on a 93 about 5 years ago and it wasn't too bad...maybe 20 minutes
Old 01-16-2014 | 04:59 PM
gorms's Avatar
Headlight switch or plug behind it is common to burn up, especially if you run the dash lights dim (adds heat to the switch). The early pull-out type switches for sure anyways, not sure how often the turn ****-type fail.
nfc90
10-28-2019 05:24 AM
handymantim
16
07-30-2012 01:34 PM
vtec_vigor
21
06-06-2010 01:37 AM
FROSTY1
34
12-08-2005 10:33 PM
mamm7215
19
06-04-2004 10:39 AM
