A lot of oily grease in front of block. Is this from the breather tube?
I just purchased this 2001 Dodge Ram and I am new to the diesel forum. I see a hose on the driver's side of the block IN THE VERY FRONT that runs down into a rubber device (cup). Is this the breather? Is there anything supposed to be in the cup like a filter? It looks like the hose just goes down into the cup and that's it. The area around that rubber cup is covered with an oily film and grease. Can you help me please?
That is the "puke bottle" and you are correct it is a breather for the engine. Should be cleaned every time oil is changed, no filter just a dirty little bottle. Most times it is way overlooked. Check also to make sure that the oil is not caked on the radiator, as this will cause some overheating issues.
azmusclecar,
A lot of us have gotten rid of the puke bottle altogether and extended that hose down and back a little. It`s only a ten minute job and it keeps the radiator and engine nice & clean.
Also, it`s a good idea to fill out your signature so we know what kind of a truck yer talkin about.
Welcome to the site
Dave
Welcome to the site
Dave
azmusclecar,
Welcome to the site
Dave
Welcome to the site
Dave
I like the idea of removing that bottle, it just doesn't make sense where it is. I guess the design engineer had too many martinis at lunch when he decided it should be where it is.
I have been trying to read up on all the stickys educating myself as to what to do and what not to do and like mnay other forums there is such a wide array of varying opinions on everything from what fuel filter to use to adding a power module to not not adding one ............so this feels right at home to me. I just need to get up to speed on diesels, this one being my first.
One member already chatised me for not reading everything on this forum BEFORE I bought the truck. He scolded me on not knowing about the block code 53.
Wow........what a moron I amI'll try to catch up
Don't beat yourself up tooo bad over not edumacating your self before buying. I found this site and another after i bought my truck after i found these sites and started looking at my truck real good i found i have that 53 block oh well i guess i just have to hope for the best
My truck did not come with a breather bottle, and had the breather tube recall done. This turned the breather tube into a front axle lubrication device. I put on a new longer more flexible tube and attached it to a custom built catch can with drain. No more driveway drips! Now, to fix the leaky oil pan gasket.
I guess everyone has their priorities in life, except my homeowners association just doesn't have a life! yes I know....I accepted that when I moved into this place! ARGH!
most HA's are a joke. there is no way i would let a group of snooty pencil pushers tell me what to do with the property that i would be forking over my hard earned $$$ for.
now if the pres. of the HA was a diesel person, that would be cool.
07_Ram
03-19-2012 02:23 PM
Forty-Two
10-22-2008 11:55 PM
azmusclecar
31
03-31-2008 11:53 PM
big jimmy
07-03-2006 12:59 PM
