looking for advice on where to attach a fuel pressure guage on a 2001.5
I've searched and searched but only found info on the 99s which has a metal cover on the fuel filter. Is there somewhere else I can attach a non permanent pressure gauge similar to the 99's where its just a plug tapped in the top of the fuel filter. After reading every thing about the Lift pumps, I'm a little worried and would like to check this before the warranty runs out.
thanks in advance.
Steve
thanks in advance.
Steve
Re:looking for advice on where to attach a fuel pressure guage on a 2001.5
Steve,
Yes, you can get an adapter to tie into the schrader valve on the VP44. Put it on the end of a grease gun hose then tie in to your gauge. You should really be checking WOT pressure so I would suggest installing your permanent FP gauge FIRST if you have a couple of hours to spare. It is well worth your time!
-Jason
-Jason
The Schrader valve on the injection pump is the same fitting as the old R12 air conditioning ports. I used an old charging kit hose and cut it off at the valve. I connected the hose to a hose barb fitting with a clamp and screwed that into a gauge. It works great. The only expense was the guage.
what is the negative re****ing attaching a fp gauge full time to the shrader valve? No one seems to do this and I wonder why?
[quote author=Rattletrap1 link=board=5;threadid=20189;start=0#msg190130 date=1064721744]
[/quote]
I have mine attached there. It's been on the truck for over a year. I had a small leak once, at the fitting. I found the fitting had vibrated loose. I tightened it and have had no problems since. If any others have had problems, I'd like to know too.
[/quote]
[/quote]
That is the test port the dealer uses when they do a fuel pressure test.
I personally would leave that valve open so the dealer has less to give you any flak about.
phox
[/quote]
phox
I second what Phox said about leaving that port open for dealer use. I used a tapped banjo bolt on the bottom of the fuel filter cannister (there a several places you can get those and I think they are only a few bucks). That leaves both ports open for dealer/mechanic use and is still post filter. Leaving that port open also allows you to occassionally check your permanent gauge for accuracy. It is also a little farther away from the vp44 and its incessant pulsations.
Thanks for the great advice guys. I only came across this site less than 2 weeks ago and have learnt more in those 2 weeks than I have after owning the truck for almost 3 years.
bigragu
01-24-2006 11:16 AM
PapaPerk
01-10-2005 08:09 AM
HOdiesel
12-30-2003 08:29 AM
