Looking for.............
the easy way to replace my heater core, note I say EASY WAY. Step by step instructions would be great!!!
Thanks in advance
PS any other thing in there that commonly breaks upon removal or install??
Thanks in advance
Actually it is quite simple Just take the steering column out, disconnect all the wires from the dash, take the bolts out at the windshield, loosen the bottom bolts, take the dash out. Now you are almost done, just drop the air conditioning and disconnect the heater/air unit and remove it.
Actually you can try to get it out with the unit in the truck, but it is tight and not too pro.
See isn't that easy, now just put it all back together again. I really enjoyed doing mine
Thanks for the input fellas!! I know I can do it just been putin it off for a long time but it's startin to freeze at night here and there & would be nice to have some GOOD heat also gonna change coolant & go with the GOOD Cummins t-stat, thanks again for your help!!
Well the core is in! Wasn't a bad job, just time consuming. My oe D/C book just said take the dash and disconnect all the electrical connections. To me that means take everything out of the dash, that's what I did but didn't need to for the method of core removal I chose. I got the dash wired up to the pass grab handle and looked long and hard at the whole procedure of removal to change that P O S core and I decided to just cut the lines and have a union under the dash. And for you critical folks out there yes the claps are good and tight as a matter of fact I used silicone heater hose. I post an update if they leak!!!!!!
Originally Posted by Mopar1973man
The green waterfall... Or the sounds of a babbling brook...
Don't worry to hard there is a TSB for the babbling brook noise... My Mom's 1996 Dodge RAM has the noise and I don't worry about it. I just make sure the radiator and the bottle are full. As for the green waterfall that is a failed heater core...
Link to the TSB is...
http://dodgeram.info/tsb/1999/09-04-99.htm
It's all good...
It's all good...
Originally Posted by Dave88LX
How much did you pay for it and from where?
It's all good...
It's all good...
F1B3R
01-02-2011 09:59 PM
89dieselkong
02-12-2010 01:47 AM
theIntlEggrole
07-16-2007 06:53 PM
bob95065
39
05-07-2007 10:48 PM
