location of speed sensor?
Working on a '93 250 Dodge Cummins Diesel 4WD. Speedo went wacky intermintantly. Then speedo and odom wouldn't work (mostly in rainy weather). Cruise control didn't work either, nor did overdrive. Now speedo/odom/cruise/OD don't work at all.
Gonna replace the speed sensor first, since we have that. Now for the dumb question... Where is it located? I've seen about 4 diferent different versions. Hoping I can get an answer from someone who has one...
If speed sensor doesn't fix everything, we'll try the instrument cluster next. Does this sound like the way to go? Any advice is appreciated.
Thanks in advance,
Mac
Thanks in advance,
Mac
I had the same issues a couple of years ago and it was the sensor on top of the back axel. You can try to clean it up as it might be covered with crud and fairly easy to replace. When mine went out, the spedo died and the abs came on.
Q
Q
Same here, but I had to replace mine.
torrey
10-25-2006 07:42 PM
