Installing cab lights?
I was interested in installing overhead cab lights on a 2002 2500 with the older body style. Does anybody know if Mopar still sells the overhead cab light kit for the older 2nd gen RAM's. I was wanting to get the original kit from Mopar instead of getting the aftermarket lights....
Thanks for any help & suggestions.
Yeah they still sell them. A friend of mine bought some for his 05' a while back. Later we found out that the dealer sold him cab lights for an 02' body style truck. He might still have them cause he recently swapped them out for some recons. He's on here let me check for his login name.....
Ok, check on here for TNLoneWolf and send him a message. I'm sure he's still got the cab lights. I'll call him today and confirm and tell him if your interested in buying some used ones.
A few years ago my friend had some put in when his truck got painted. And the body shop had to wire them in from scratch because dodge had quit making the harness. Hopefully you will have better luck
The part number you want is 82207252 This includes the lights and harness, it also includes a template but it is for third gens. Check out this post https://www.dieseltruckresource.com/...ab+roof+lights and this write up http://www.phildorsett.com/clearancelights.html
You don't need no stinkin' template. Pull the headliner and it has five holes in the inner sheet metal layer where the light wires protrude. I had my headliner out in less than 10 minutes so don't fall for the "takes to much time" line. I drilled a hole for my main wire dead center on the holes on the inside, fed the wire through the outside to inside with the light. Eyeballed the lights on the roof, took some measurments to make sure they were within tolerances(1/8" or less) and drilled the holes. Watch your drill bits, that second layer on the inside will break them.
I screwed them down and tadaaaa, pics in my gallery.
It's not that big of a deal, a wire harness is a plus though, speeds things up for sure. If you don't have a bunch of other lights and such you could probably get away with connecting them in with your parking lights but just watch how many lights you put on that circuit.
rollerink
04-09-2008 08:47 PM
mattbotkin
06-22-2007 08:02 AM
subspd
35
10-26-2006 03:39 PM
rattle_rattle
07-25-2004 02:58 PM
