Hydroboost/Brakes Question
Old 08-29-2012 | 08:10 PM
steven.m.coon's Avatar
About a month ago I rebuilt my hydroboost because the seals were starting to leak. I replaced the master brake cylinder when I did the rebuild since I had it off. Now I cannot seem to get the brakes to work right. I bench bled the master cylinder so I know its good. Checked all the lines and no leaks. Would the hydroboost in any way make my brakes get air in the lines or did I just not get all the air out of my line?
Old 08-29-2012 | 11:25 PM
rebal's Avatar
hydro is a seperate system if you have spongy brakes you have air. if you have low pedal your rears (if drum) need adjusting
Old 08-30-2012 | 11:54 AM
Redlinear's Avatar
Park the truck on it's nose (jack the back of the truck up till the front bumper is on the ground...or best you can do).
Then bleed.
thechoochlyman
10-26-2016 05:15 PM
jarvis243
09-18-2012 10:10 PM
Superduty
12-18-2005 03:45 AM
apache
07-10-2005 04:14 PM
