How do I replace my headlight switch?
So.. How do I do it? Does it involve removing the entire dash face plate? Any help would help... On the 94
Remove 2 screws holding in the cup holder and remove it. Remove 2 screws holding in the ashtray and remove it. I usually start above the radio when removing the dash bezel. You can pull out on the dash bezel pretty easy above the radio (for me anyway). The bezel has clips that hold it into the dash. Pull the bezel back firmly, but don't yank on it. Tilt your steering column all the way down. Be sure to unhook the wire going to your 12v accessory/cigarette lighter plug. Just take ur time, it's pretty easy to get out. After you remove the dash bezel, you will have access to the switch. I believe there are 2 or 3 screw that hold it in also.
Three screws hold the switch in the dash. After you remove them and the switch you can unplug it. Then you remove the **** and face plate, and install them on your new switch.
Very timely info as my switch is bad, too. I picked one up at local auto parts store and the switch aslo came with a replacment connector.
How often does the OEM connector burn up?
I don't know, but my switch does not have a plug on the back. It is just female spade connectors. Probably previous owner crap. But it is good to know they come with a spare plug, since I would like to change mine out.
1 Post
The wire harness beneath the drivers battery tray gets a lot of corrosion in the north country. This happened to mine and melted my plug too. I had to fix the rotted wires, then fix the plug.
I don't know if a 97 is different than a 98, but my new switch matches the photo in the service manual. Switch has male spade contacts and the wire harness connector has female. Just not looking foward to splicing 9 wires. Kinda chilly outside.
I just did a switch last night, If memory is correct this is the 3rd or 4th one.
I prefer to leave each connection loose, with there own terminal. the factory harness plug melts out, and your stuck re doing that whole mess each time.
If it has gone out , take a few minutes, look at what is going on, it will most likely go out again.
The previous owner must have subscribed to your ideology, because mine is done just like that.
jesse123
07-08-2012 09:04 PM
Varmint
01-20-2009 08:01 AM
Barryn
07-14-2008 09:30 AM
Thunderjet
11-13-2005 10:05 PM
jlipskoc
10-24-2005 01:16 PM
