Horn Problems
Horn Problems
OK guys, one of my horns ( the high one) on my '97 doesn't work. I've checked the fuses, switched out the horn relay and I've hooked up a tested horn from a Caddy. No good. Any ideas that would get me on the right track.
Thanks in advance
Thanks in advance
Mine is doing the same thing. Here is what I am gonna do.
http://www.stebel.it/stebel/index.htm
139db at about $50 all over Ebay - also I understand NAPA and AutoZone are going to start carrying soon.
almost like an airhorn but a lot cheaper and easier to install.
Plug the good one into the connection for the bad one, to make sure it's the horn and not the wire. If it works, replace the horn, if it doesn't check the wireing. The Caddy horn may be bad too.
