Holley Blue
Holley Blue
A year or more ago, I installed a Holley Blue on my truck. I saw about 13.5 psi for a while and it has been steadily declining. I'm now looking at 10.5 psi at idol and about 9 wot.
I think i've heard that there is a screen that should be removed because it is easily clogged. How can I access that screen or could my pump be on the way out?
We have 2% biodiesel here and the pressure typically drops to about 10-11 cold and 11-12 warm. It will go down to 5 at -15 F. Summertime it goes to 13 steady.
Possibly it's time for a rebuild. Get parts from Summit. Also the relief valve may be worn. I use a Blue on my streetrod with gas and it's good for a year or so. I won one in a contest so I didn't even fix last year's.
^true. Remove the 4 bolts on the bottom of the pump, take the brass screen out and reassemble. In order for these pumps to survive, they need a pre-pump filter....install one before the holley pump. Almost 2yrs w/this setup and constant 18 idle/15wot.
Thats reading the pressure at the fuel filter. The fuel filter is clean I changed it about a month ago. I'll try removing the screen and see what happens.
Just a thought: When my stock LP went out, I put a Holley blue in place for a little while to see if it worked (it did), as I have several I use for gas applications. I noticed on the stock LP, the vanes inside are at a different angle than the Holley vanes. This may be due to the diesel fuel viscosity, I don't know. But they are different and the blue pump I put in didn't last but a few days (it was old anyway, but a good spare for gas). My feeling is that the diesel fuel puts quite the strain on them and the price difference for a stocker vs. a blue just isn't enough to warrant saving $60. Stock LP ~ $190 from the Cummins dealer. And I never use the screen, instead I plumb it downstream from a filter (gasoline apps). IMO, your's may be wearing out the motor and that's why you are seeing lower psi.
that might explain why I had one self destruct..
i was thinking it over heated..
did you notice if the angle was in the same direction as the rotation. just different..say 10 degrees vs 25 degrees..just wondering..
-dkenny
-dkenny
The angle of the vanes in the stock pump was like they were leaning back out of rotation I believe. The Holley vanes are straight out perpendicular. Similar designs other than that. Good for gasoline, maybe not so good for diesel fuel.
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
