Higher RPMs
Higher RPMs
It seems as though this truck runs at a much higher RPM than my 03. I am seeing about 2500 RPM when running 60 - 65 MPH. Is this normal?
ID
See if there is a tag held on the diff.cover by 2 bolts , you may need to clean off with wire brush to read numbers, if no tag then get this info off truck , tire sixe, RPM at a speed with no load and flat ground then do a search here , you should find a chart that will tell you the ratio with that info.
Originally posted by ViperSBT
Just took a friend out for lunch, he thought I probablly had the 4:10 as well. Anyway for me to identify if it is 4:10 or 3:54?
Another way to find your ratio is too look on the inside of your glovebox. There should be a white sticker with the ratios as well as a few other options.
jschintgen
12-31-2009 11:17 PM
