Help me figure out if I have 4 wheel ABS.
I just ordered a set of wheel bearings from Discount Auto Parts and according to their site for my truck (1996 4WD) the only bearings they show are the ones without the ABS sensor. I was looking at the specifications sticker under the hood of my truck this weekend and it seems to me like it says I have 4 wheel ABS. Is this right or did I misread it? Was 4 wheel ABS an option in 96? If so is there a way to look at the front end before I get it apart and see if there is a sensor there or not? Thanks
If you have 4 wheel abs there will be wires going out to each front hub , and under your hood there will be a big abs doohickie right behind the PDC.
4 wheel ABS was an option in 96. On a 4w abs the control unit takes up quite a bit of space on the fender outside from master cylinder, on 2w abs there is a big open space.
Almost certain on '96, definitely sure on '94&'95 that the unit bearing is the same for 4 wheel abs as 2 wheel.
For sure on '97 the hubs for 4w abs are different than for 2 wheel. The difference is the sensor tone ring is part of the bearing on '97 up. Big price difference too.
mechmagcn
02-02-2013 09:02 PM
armourbl
03-07-2008 11:03 AM
ouchman
06-08-2006 10:44 PM
Dan Marino
24
05-15-2006 08:30 PM
