Help! I need 96 fog light switch pin-outs
I'm putting in aftermarket Hellas with their relay and Dodge OEM fog light switch. I want the OEM look with the ON light and the interior dimmer light working. Any help?
Your best bet is the factory manual. You can most times find them at the libary and the photo copy the pages you want unless you want to buy one $$$!
I used the factory switch for after market lamps and had little trouble figuring out the pins with just an ohm meter. One pair of pins is the switched negative load, one pin to positive to run the lamp when on, one pin to the dimmer lighting circuit.
CTD NUT
03-10-2010 01:28 PM
Scott_321
08-15-2003 06:22 AM
