heater only works on high
my heater switch only works on max.... direction and where it goes works perfectly but like if i try to turn the heater to 3 it turns it off.. same with 2 and 1.
any ideas?
any ideas?
Our 95 gasser at work did the same thing. Replaced the resistor. It worked fine a few days then burned it out again. Blower motor pulling to much juice. Replaced motor and resistor . Running fine now.
If it burnt up the resistor make sure you check the wire terminals and replace the burnt ones. Otherwise it will burn up the new resistor from bad terms overheating and burn up again.
hey i phoned up for a price from napa the other day and they said like 90 bucks from dodge!
is this just a resistor i can get from radio shack or whatever, if so what size?
thanks
thanks
You can pull out the resistor and take a look at it. Sometimes they can be "repaired", but that is your call. It's easy to get out. Disreguard my above post, I was thinking of the mode door motor location, not the resistor. Resistor is EASY.
chainzaw
10-14-2009 07:46 AM
Diesel- Dummy
01-19-2008 12:35 PM
