Heated mirrors not working
Same here... the drivers side doesn't work but the passenger side works perfectly. Do the elements go out in these?? That could be my problem but I'm not sure why both of yours would work. Maybe a relay??
The wires that make them work are right behind the door panel. I would take off the door panel and start checking the wires with the volt meter to see if you have power to the plug. If so, the issue is probably with the element, if not, trace it backward until you find voltage.
Sleigher
05-04-2017 02:12 PM
ChicagoSnow
56
01-26-2008 12:09 AM
