headlights
headlights
ON my 99' 4x4 my headlights on dim are like a flashlight you bought at the dollar store on clearance but my brights work great .I have replaced the multi function switch and headlight switch any ideas?
Have you tried new bulbs? You could have a bad ground. Check your battery terminals and grounds. Worst comes to worst, you can just buy or make a new wiring harness for the headlights. Ebay or www.suvlights.com sells them.
I would check the connectors for the bulbs. It's quite common for the terminals to become loose and then burn up from the resistance. It will be obvious when looking at the terminals if this has happened.
I have looked at my grounds and they seem fine .I have also replaced my bulbs with silverstar which i find here are probably the best . I havent tried the wiring harness yet that will be my move for the weekend . That and the GM wheel cylinders.
Get new headlights ones with clear lenses, something like these http://cgi.ebay.com/ebaymotors/94-01...mZ130248891513 or even better get the sport headlights with two bulbs like these http://cgi.ebay.com/ebaymotors/DODGE...mZ180281273872
If you really want good lights, get some HID lights. I got so I hated to drive at night because of the combination of my old eyes and the crappy stock lights. I tried Silver Stars, bright box and still hated it. Got some HID's, didn't like paying so much but now I see very well at night.
I bought these: http://cgi.ebay.com/ebaymotors/1999-...mZ380057977291
Installation details here: https://www.dieseltruckresource.com/...d.php?t=191370
Couldn't be happier with them.
I guess if thats the way it comes factory . I havent done any rewiring YET but it looks as if that is going to be the route i have to go and may need some help with that i have never tackled anything like that
To use the sport headlights you need to get a wire harness like here for $133...:
http://www.suvlights.com/product_inf...roducts_id=116
....or make yor own harness like here:
http://www.danielsternlighting.com/p.../products.html
....scroll toward bottom under "Headlamp Relay Installation Kits" and buy the parts from him except for wires using "RIK-RAM kit to properly install improved Dodge Ram Sport" for $79 or do it yourself using a diagram on Daniel Sterns site.
I am considering the suv harness already made up.
Dave
Dave
Ya there is good info on daniel sterns site. I dont remember what year dodge went to ground switched for the headlights on these truck but on my 01 the headlights are ground switched. Which means that the power goes the one terminal on the bulb and wheather you go high or low beam determines which of the other two terminals ground. Sorry for the poor wording lol. Just something to think about becouse on the diagram on his site it is for a positive switched setup.
I second the Daniel Stern site, a must read if you have headlight problems. Going with relays solves a lot of problems and allows you to add to your lighting system w/o worry about overheating the headlight switch. Also try this site for more info: http://www.madelectrical.com/electri...adlights.shtml
Floyd
Floyd
hi
solved my headlight prob with the relay harness and some flosser bulbs and putting dielectric greese on every electrical conection i could get at .
also added diode to run high and low beam together !
Those are for the 1500 truck. Are they the same for the 2500?
