Headlight stopped working and brake light isn't on
I recently picked up a 1997 2500 CTD. The headlight was working when I picked up the truck but while idling it home, I smacked the dash because it rattled like hell. I also played with the headlight switch (seeing how the doom and cargo light works) when I realized my headlight stopped working.
The high beam works but the low beam doesn't. It 'could' be the bulbs but I'm pretty sure it's not because both side stopped working. I checked the fuses and it's fine. The only other thing that could have cause the problem is me smacking the dash and playing with the headlight switch.
Is the headlight switch failure a common problem on the truck? I suspect this because the high beam is on a different switch and it still works.
Second problem, I removed this 'aftermarket' (doesn't have any dodge logo on it) controller. It's mounted to the panel under the steering wheel and it doesn't look factory .. too ghetto rig. I was following the harness (after the crimps) to remove it completely then I discovered the harness goes to the factory wiring loom. There is a label on the harness that says "electric brake". After removing the unit, my "BRAKE" light doesn't show up anymore when I engage the parking brake. The unit has four wires .. black, blue, red, and white .. which matches the factory wiring but it was hooked up with blue going to red and red going to blue, black to black and white to white, or something like that.
Is this unit a factory item? How is it wired and by removing it caused my 'BRAKE' light to stop working?
Last, where do Dodge owners go to pick up OEM parts? Partznet.com has Chrysler/Jeep but no Dodge. Local dealership .. haha.
first4age
Welcome to the site... I am by no means an expert, but I would suspect the switch. I have read several threads on here that talk about the switch failing... especially if you have the dimmer turned down. Try doing a search for head light switch..
As far as the box you removed.. it sound like it was an electric brake controller... Do you have a 6 or 7 pin connector in the back of your truck?? Do you know it the previous owner towed any thing?? Not sure if this would effect your BRAKE light no turning on, but any thing is possible.. As far as it being factory, you would have to get the order sheet to see if it was ordered with a tow package..
Can't help you with OEM parts...
you may want to post this to the help forum and see what you get... Not sure if you can transfer this or post new...
The headlight switch tend to overheat and fail. You can pick up a new one from most auto parts.
The wire colors on most brake controllers don't match the trucks wiring. I've known quite a few folks with light problems that were cured by removing the brake controller.
The controllers are all aftermarket.
Thanks for the welcome hekroh. I didn't realize there was a search feature until you replied. (I guess you have to registered and sign-in, in order to have the search feature.) I just did a search and WOW .. this seems to be a common problem.
The truck does have a 7 pin plug on the hitch. I'm looking at the original window sticker and "Trailer Tow Group" is listed as one of the option the original owner purchased. Here are some pictures of the unit I removed.
Is that the OEM (or the aftermarket unit Dodge used original) electric brake unit?
Originally Posted by infidel
Like I said there is no OEM controller they were all after market and not included with a new truck. The towing package is just beefier springs and heavy duty turn signal flashers.
I got the headlight fixed and it was the switch. Picked up a cheap NAPA switch since the dealerships are 3+ times the price ($89 vs $24). I'm going to get the summit racing harness too so I won't have this issue again. (hint: there is a spring loaded button on the side which you push in order to pull the rod out. It took me forever to pull the rod out since I didn't know that.)
I also fixed my BRAKE light. Turns out, when I was cleaning the gauge cluster, I had to remove the lower bulbs to put the clear face out. When I put it back, I must have installed a blown bulb in the BRAKE side.
BradKnight
01-07-2013 12:34 PM
CaledoniaOutlaw
11-27-2012 12:52 AM
Joey-D
12-12-2011 01:52 PM
The_Head
12-05-2008 04:20 PM
fmandan
09-15-2007 04:49 PM
