Headlight problem
Headlight problem
Hello all!
I am needing some advice. I have an 02 3500 SPORT model, so it has the quad headlights. Problem is that I have no low beams or factory fog lamps because the high beams are stuck on. The DRL's work fine and all other aspects of lights work ok but once I turn the headlight switch on my high beams come on and I can not select them off. Awhile ago when I had the high beams on they would flicker off and on real fast. I am thinking the headlightswitch but could it be as simple as the relay in the under hood fuse panel?
Any help or insight would be greatly appreciated.
Thanks,
Steve
I searched and found a lot of headlight related problems but not this exact one.
Thanks again.
Thanks,
Steve
Thanks again.
I have a 97, and when my high beams came on constantly all the time it turned out to be my Daytime Running Light (DRL) module, which is a little chuck of black plastic that has a multi-pin connector going into it. On my truck is was located on the driver side fender under the hood (kinda in the corner).
When I unplugged it, the high beams turned off. I ran without it for quite a bit before finding a replacement one at a reasonable price at a wrecker.
Sean.
Sean.
Sean.
Sean.
Thanks! Exactly what the problem seems to be. Please check your pm s as I have another question for you. Thanks, shrmpboatcptn, busboy, haloman for the suggestions.
Cheers,
Steve
The multi function (high/low) sw being dirty is a common problem and previously reported that cleaning with contact cleaner at the same time as operating the sw (with headlights off) fixed the problem.
mtdoragary
11-07-2013 08:31 AM
jlipskoc
10-24-2005 01:16 PM
