Gelled Fuel? What to do?
#31
Straight anti-gel formulas do not work on already gelled fuel. You need the melt-down (911) formulas (that contain alcohol) to thaw gelled fuel unless you can get the truck into a heated area or have Mother Nature oblige with a nice warm spell.
Instructions on the fuel additive bottle should remind you to add to warm fuel for maximum effectiveness. I run my tank very low in the winter so I can fill with a lot of warm fuel and dump in my additive.
If you can warm up gelled fuel COMPLETELY you shouldn't have to drop the filter and can avoid using the nasty melt-down formula. Just need to get it started and let the fuel circulate well before letting if cool too much.
I don't use Power Service. If you want something commonly available that works better, try Howes. I actually use other (better) additives, but they are not available in all areas.
Cold?
The populated/coastal areas of Alaska are usually warmer than me in the winter.
I assume RUG is Regular Unleaded Gasoline? Not for the common user with a modern diesel. Yes, it does break up the wax, but get the ratio off and you risk serious engine & pump damage.
Cold?
#32
Back when ATF was basically #10 nondetergent oil it worked as a diesel supplement. Mostly used to justify that red tint in your fuel from using the wrong pump...
#33
I just looked at where your at fueling & you can sure spell cold.
And yes RUG is reg unleaded gas & I have gone as high as 10% in cat's, IDI's older cummins but wouldn't go that high in a common rail or similar.
#34
#35
#36
Thanks for all the replies you guys but i got it running the other day... So i personally dont need any more info... ACTUALLY now that i think about it, keep the posts coming. Im sure this information will help me in the future and/or someone else.
#37
Like I said, a mechanic's tale from the 60s. When you get your fuel tank dipped by the tax men, how long does it take to convince them that it's atf?
On edit, just read what RUG is. Since you are dumping gasoline into the tank you may as well continue the atf. The engine won't last long enough to see if the atf damaged it.
#38
That's why the sample goes to a lab before you get a ticket.
#41
I buy the little bottles a case at a time and it is cheaper than the truck stop stuff. Is price the only reason no one uses it? I always have heard you want an additive that seperates water and it is the only stuff I have found that does that?
#42
For me, too hard to find. Only know of I place in the area that carries it. and I usually don't get there when they are open.
My brother brings me Penray every Thanksgiving. That is still my favorite.
Power Service is the only thing that does not slush up on me in the winter.
I use an old Power Service jug filled with #1 and a dose of additive for a fill up. It stays in the toolbox next to the fill cap.
#44
As for long term damage if using WMO or ATF saves me as much as it has proven to for over 40k miles in my ferd I save enough to pay for a a complete fuel system every year or a rebuild every 3rd year. Filter well before adding it to your tank know your source & the risk, if your so broke that the reason to run waste is you can't afford anything else then I submit you have way bigger problems than we can fix here. Cummins has had a system that added oil to stationary units as they ran & many of those motors ran on that blend for years, yes at lower ratios than some of us are running which just brings the rebuild time foward, I still contend that if your saving enough to more than pay for the damages as my experience has shown then your ahead of the game.
#45
Umo
Do you filter it before putting it in the engine? or just pour the thick black stuff right in? How many miles have you been doing this for?, and have you had any issues from doing it?
Mark
