Gearshift buzzing sound
Old 03-27-2005 | 03:46 AM
KTM rider's Avatar
I was wondering if anyone elses gearshift on a manual trans ( 6-speed) makes a buzzing sound? This is very irritating. I can spin the **** and tighten or loosen it up and it quits for a minute of two but then starts again.
Is there any easy fix for this. The dealer said that they would have to tear it competely down to fix it.. Big $$$ just for a buzzing sound. Thanks...
after posting this I went out and to my truck and took off the whole shifter ****. I found that there is a nut inside the **** that apparently threads onto the gear sift shaft.
i also qiuckly found out that the little pattern plate that covers the **** is next to impossible to pry off without butchering the whole darn thing.
the good news is that I found the source of the buzzing.
The bad news is that now i need a new shifter ****.
Old 04-07-2005 | 04:33 AM
killfast1's Avatar
I had this problem. There is a lock nut under the cap on the shifter. take it out as its not needed and the buzzing will go away
Old 04-07-2005 | 04:35 AM
killfast1's Avatar
Sorry, didnt finish reading. If you use some heat and a small flat screwdriver you can get the cap back in.
Alaskaworktruck
09-08-2013 10:32 PM
mstep3
10-21-2010 08:05 PM
Thundercloud
10-25-2006 03:24 PM
alltimelow1
10-04-2006 07:07 PM
signature600
01-24-2004 04:40 PM
