gas tach conversion
gas tach conversion
i think this will work for both 12v and 24v but i did a 12v so here it is you only need a phillips screw driver
remove the threee screws from the back of the tach
i got the gas cluster from my parts truck and took the cover off
i belive there is seven screws
then you can remove the tach gauge and do the same process on the diesel cluster and you can have a gas tach
Are you sure your RPMs are correct? At least on the GM vehicles, 6 and 8 cyl. tachs took different electronics, made it hard to swap clusters into our 9C1s.
They had differing resistors IIRC.
THURENfab.
08-08-2007 07:02 AM
Scovo1
30
05-11-2007 01:08 PM
