Fuel Tank Module Swap Question
I am asking this for a guy who needs a replacement fuel tank module for his 98.5 diesel Ram. He has located a used 2002 module and needs to know if it is compatible to his truck. Many thanks for your help here.
I can't answer your question but does he really need a complete module?
If just the sender is the problem he can get one from the dealer for around $60.
If the lines are rusted out he can use one of these> http://www.vulcanperformance.com/Dra...shlo-p/dsi.htm
Those are about the only things that can go wrong with a module unless it's totally missing.
The 90 degree bends in the fuel lines at the module got hashed from corrosion. I can't physically see his project and therefore don't know the full extent of the situation but the draw straw might do the trick, Thanks for your help infidel!
