fuel gauge sending unit
Old 09-27-2003, 11:40 AM
powerwagon440's Avatar
need a little help my dad has a 98 12v and it has a bad fuel gauge sending unit! was wondering where i could purchase one for him? if anybody had a good place or some recommendations? any info would be great thanks guys! Andy
Old 09-27-2003, 02:54 PM
Haulin_in_Dixie's Avatar
Re:fuel gauge sending unit
Your local discount dodge dealer
Old 09-27-2003, 11:09 PM
anywhere else besides the ******* please!! Thanks!
Old 09-28-2003, 05:25 PM
Marine's Avatar
How do you test to see if it is the sending unit? My gauge quit working, but I assume it is the sending unit. I would like to do some sort of test to make sure it is the sending unit before I pick one up.
Mike
Old 09-28-2003, 08:40 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Try grounding the wire form the sending unit and see if the gauge reads full.
Try www.mopar4less.com
Old 09-28-2003, 10:11 PM
Marine's Avatar
[quote author=Shovelhead link=board=5;threadid=20230;start=0#msg190350 date=1064799655]
[/quote]
what if it does? or what if it doesn't? what will it mean if it does either one?
mike
Old 09-29-2003, 05:59 AM
Shovelhead's Avatar
Sorry :-[
If you ground it and the gauge moves then the gauge is ok and the sender is toast.
Ed
Old 09-29-2003, 10:48 AM
Marine's Avatar
Thanks Ed. Where is the best point in the harness to take the wires apart?
Mike
Old 09-29-2003, 12:25 PM
Marine's Avatar
I just found out 'Mopar 4 less' is not for less.
http://www.dodge-auto-parts-dealer.com/parts.htm
is cheaper.
There are 3 things in the Fuel guage Module kit.
P/N 4897668ae-Module- Pump, FP regulator, level unit. about 340.00
P/N 4897669ab-Level unit only- about 37.06.
Mike
Old 09-29-2003, 01:16 PM
Mike you should need the "level unit" only. Unplug it at the tank where it plugs in on top.
Old 09-29-2003, 02:26 PM
Marine's Avatar
I will need to drop the tank I imagine. Is there any type of gasket I will need to replace? Is the level unit seperate from the rest of the components in the tank?
Mike
Old 09-29-2003, 03:03 PM
Shovelhead's Avatar
Check here for some instructions on changing the sending unit.
http://www.dodgeram.org/tech/repair/index.html#wiring
Old 09-29-2003, 03:12 PM
Marine's Avatar
Thanks Shovelhead!
Mike
Old 09-29-2003, 03:36 PM
Marine's Avatar
I am going to try that teflon washer fix, but I can't get a hold of Huey Conway. His e-mail address does not work. Does anyone know him?
Mike
Old 10-15-2003, 12:11 PM
alleyyooper's Avatar
Still wondering about that teflon washer source myself. I really need to do the fix, have been living with the thing going bonkers way to long.
;D Al
Quick Reply: fuel gauge sending unit
