Fuel gauge reads 1/8th tank.
I normally search before posting search but I didn't this time so bear with me.
My fuel gauge is not working.
It will constantly read around 1/8th of a tank with the ignition on.
I will be installing a FASS system soon and plan on looking into the gauge issue at the same time.
Since it looks like the system may actually work, I was thinking the float could be bad causing it to sit in that same spot?
What are your thoughts on this idea?
What kind of float do these trucks use?
I have had to replace a couple on other rigs in the past that were simple brass floats. The fuel would eat them up and make them leak.
I have a couple spares in the shop that could be swapped in if these are the same.
Just trying to see what I may need for this project so I can possibly lift the bed one time to take care of both projects.
Any help would be great.
Thanks, Ken
Thanks, Ken
it uses a real hard foam/plastic material or something i just replaced mine because it was always reading full. turned out the mechanism just fell off the pickup assembly, i replaced it anyway because the float material was wasting away on the corners and i was installing a draw straw. new one cost me 70 sumpthin bucks at the steal-er-ship..
Some threads on this situation stated that premature damage can occur to the float assembly if the high volume fuel pumps are used during fill ups. The float really takes a beating as the fuel washes in. Kurt
ctd4stan
06-05-2008 08:06 AM
03qclb5spd
04-03-2007 11:42 PM
Buckshotmckee
06-10-2005 12:23 PM
xj2extreme
16
01-15-2004 07:50 AM
