Fuel gauge not working right
I know this has to have been addressed before, but I've used the search function over and over and I can't find any threads on fuel gauges not working right. My fuel gauge has now decided that the most it is going to read is just over half full. I ran fuel out on the ground again this morning because I thought that I'd need 15 gallons or so because the gauge showed just over full. I only needed about 3 gallons. Since I don't drive the truck very often I don't always recall how much fuel should be in the tank. I recall seeing other older Dodges with their fuel gauges not working, so I assume someone else must have this issue.
Any ideas where I should start looking? Fuel sending unit? Fuel gauge itself? I don't want to always be wondering if I have any fuel in the tank. Thanks.
Thanks guys. Now all I need to do is find that sending unit. Would that thing be a "dealer only" part, or might I find it somewhere else? I'm kinda hoping that it's not a really expensive thing.
Dealer only, many will tell you that you have to buy the entire module for about $300.
This isn't true, the sending unit alone is available for around $40.
I have the part number at another computer, will post it later.
Dodge p/n 4797738 all senders, diesel, '94-'97 $49
Last time I bought one here
http://www.trademotion.com/partlocat...cfm?siteid=835
Originally Posted by Dargo
Thanks again! I have one ordered. Do you really have to take to bed off to install?!
There are instructions on Fritz's Ram Page describing the procedure to repair the pivot of the fuel level sending unit. Click here
I was going to do it on my 1500 but got the entire pump assy instead because it won't hold pressure at the injectors anymore.
Thanks for the tip about tilting the bed sideways. I was going to run the tank down on gas and drop it but I think tilting the bed might be easier.
Sleigher
05-04-2017 02:12 PM
Michigan Ram
08-24-2011 11:25 PM
Big Mac
09-29-2008 08:25 PM
