front rotors resurface ??
just buy new ones, its not worth the hassel, i've had to do it a couple of times. its not too hard the only special tool you need is the axel nut socket, like 15 bucks at your local parts house. trust me its worth it, and the rotors are pretty cheap.
oh and buy the cheapest pads you can, the more expensive the pad the faster they wear out your rotor.
I don't really know about that last statement. I can get a set of organic pads for $12. I refuse to try them, but I have my doubts that organic will do a very good job stopping a load as heavy as our trucks... not to mention any load we happen to be pulling.
My gut tends to go just the opposite direction. I say get the best pads you can afford, and make sure you can stop your truck and the load you're pulling. You may have to replace rotors a little more often, but as you said, they're cheap.
If they're OEM you might be able to get them resurfaced, and I seriously stress MIGHT. If they're an autozone, advance auto, pep boys, napa, oreilly's special odds are very good they can't be resurfaced. Auto parts are so cheap nowadays it's ridiculous. I even had the parts lady who ran my local auto zone laugh when I asked if their brands were resurfaceable.
lgp, just because they are more expensive does not mean they will stop better. If you go to a parts house, their more expensive brands, or models are made to last longer, not stop better.
Now there are the exceptions to the rule with pads that are specifically made to stop better by specific companies that cater to "performance" but your regular wagner/raybestos/etc are made to last longer therefore can be sold for more money. Most regular people don't care how well they stop (as long as the work of course) they just don't want to pay a shop to replace brake parts every year.
That said, I'd probably stay away from the $12 pads as well, but I wouldn't be buying the top model either.
Travis
Travis
when i first got my truck in 01 I was told by the dealer to get them resurfaced for inspection that cost me over 300 $ and I waited all day, that was the last time that happened every since I just bought new ones they cost me about 60 each wheel I think for the rotors and weren't that hard to install
I'm at 110K and just installed my third set of linings. I've cut my rotors twice and still have alot left before min thick. Pro Cut on car lathe is an impressive piece of equipment.
hi
yea thats what im a thinkin !
a light cut and good to go has got to be easyer/ cheeeper than replacing the rotors !
what did they charge to do the cutting ?
i just have to find a shop that can do it !
If the shake is from a warped rotor, resurfacing won't help. You will need new rotors. If the shake is from glazed pads, just replace the pads if the rotor is not too ugly. If you keep the rotors, clean them and check for oil, grease, brake fluid. A perfectly smooth rotor surface is not necessary. I use the house brand pads at Auto Zone, they are cheap, won't eat your rotors, and you get free ones when they wear out. Oh, and they stop as well as any.
i will never ever buy another set of expensive pads....they were soo hard they warped my rotors from too much heat, blue spots all around...be it as it may, the cheapo $34.00 bendix has lasted me the longest now and hasnt warped anything..
Just a plain ole guy
All this depends several facts. First, if it shakes or surges during a stop, it's most likely that the rotors are warped. They can be resurfaced, if they are thick enough to shave out the runout. You'll never know untill they are placed on a brake lathe and measured for runout. A good brake shop can and in 9 out of 10 cases, measure them for free.
Don't take them to a ratty brake shop. unfortunatley, the signs don't say ratty brake shop on the front of the building. The brake shop by my work is the worst I've seen. I've used them once and will never again. I watched them break 3 of 4 lugs off of a car and tell the driver he outa get that fixed. Yes you read that right. They sent the car out with one lug nut on the right back wheel. The guy got really hacked when he was told, but the manager just ook his miney and told him to leave.
The only thing they did for me was turn my rotors. Rotors are not cheap by the way. Unless you have money to burn. I paid well over $100 each for mine. And a good shop will truew them up for about $20 each.
And stay away from Auto Zone pads. Even though they are lifetime warranty, they won't last. I've had a set fly apart and destroy a rotor. AZ was glad to give me new pads, but not a $300 rotor for our Grand Prix.
I've tried cheap ones I've tried expensive ones, and the ONLY ones I buy nowadays are the ones from the dealer. If you want "factory" brakes you have to use factory parts be it a small car or a big truck.
