Front end clunking
Front end clunking
My front suspension has been clunking for quite some time now. The ball joints are tight. My question is what usually need to be replaced when your front end starts to clunk after hitting little bumps in the road. Also if your on the interstate and hit a rough transition it feels like the front end wobbles. Any suggestions?
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
Oh when you go to check it out, have a friend help. Leave the motor off and have someone move the steering wheel back and forth while you lay under the front of the truck. If it's bad, you should see the joint moving around.
i second both of those, and check the lower track bar joint as well, the last one i put in the lower went out first?!?!?!
and never too tight on the shocks, rattle em down
I remember something similar like clunking from the front end of my 95 DTD 4X4. Every time I hit a bump I could feel it in my steering wheel. I did some on line checking an found a post regarding a clunk in the steering shaft. The shaft moves up and down with movement of the front end. The fix was using plastic tie being slipped into the sleeve (where the rubber boot is) to take up the slack/ play between the inner and outer shaft. I did just that and it corrected my clunking felt in the steering. I also check the suspension and it was tight. Its worth a check anyway.
Note: My fix was done even after dodges steering shaft fix,sometime back,to correct separating of the steering shaft, not the side to side play.
BMH95
38
12-17-2013 05:46 PM
Remnik
04-07-2008 06:28 PM
mega-engr
27
02-04-2008 12:00 AM
honda_guy4
12-04-2007 07:19 PM
benfordj
09-08-2007 11:45 PM
