Front end clicking? Stops when apply brakes
I did the brakes about two weeks ago, recently have a clicking/vibration that occurs from around 20-55mph. The noise stops when I hit the brakes. Any suggestions.
Thanks guys, I usually turn the rotors but they looked brand new so I left it, not to mention I was in a real hurry. It didn't seem to make the noise until after I had driven for a week. Any other suggestion.
Check your front hub bearing assemblies. When they go you're stuck. Jack up each front wheel and grab the tire at the 9 o'clock & 3 o'clock position and try rocking the tire back and forth. If you have play in the wheel it is more than likely the hub bearing is on it's way out.
Mine would stop clicking when i got up to certain speeds, i dont remember if it would quit when i applied the brakes or not. It could put a little pressure on the ujoint and stop the clicking, but i am by far no expert. some of these others might be able to tell you more i am still learning and just try to help with things that have happened to me. my bearings went south on me too but when they did it was bad i could tell, course when i took the hub off the chewed up bearings fell out on the ground, so i let them go way too long.
Thanks guys, I will start with the wheel bearing. That was my first instinct. If one goes out is the other shortly to follow. In other words should I do both sides at one time and be done.
austin1972
02-09-2011 08:10 AM
doomgaze
04-26-2006 05:28 AM
Dodgezilla
03-30-2005 06:00 AM
